IE7 Beta 2
IE7 Beta 2
is anyone else using IE7 and having problems viewing the PlusNet portal? parts of the site won't load but are fine in Firefox.
Any suggestions welcome
IE7 Beta 2
This has come up several times over the past few months and been answered (hint: use the search Wink).
Yes, IE7 has problems with the portal and is not recommended for its use. While IE7 is still Beta, PN are not going to spend a lot of resources of investigating why.
IE7 Beta 2
I'm not sure what problems people are having with IE7 Beta and the portal, it seems to work just fine here (IE7, XP x64) aside from the fact that IE7 uses its own fonts which make it look ... odd.
Back to firefox for me!
(this message posted with IE7 and no problem navigating the portal to get to the forums)
IE7 Beta 2
Not picked up on the different fonts thing.....
IE7 Beta2 XP Pro
Everything I've found works fine - and believe me I've looked pretty hard for errors.
shellsong
IE7 Beta 2
I don't think I'll bother with IE7-- it doesn't work too well with Linux! Tongue
IE 7
I installed IE 7 about a week ago. I found that it was not loading all the images in most of the pages i was viewing. Gone back to trusty old Firefox.
