IE & OE Taskbar logo's!
Please can someone tell me how to remove the Packard Bell logo's on the taskbar of Internet Explorer and Outlook Express.
Thanking you in anticipation :!:
You will have to edit your registry for that, but if you are unsure either get a friend that knows or best left alone.
Edit registry!
That's no problem to me, but where's the entry?
Or, if you use Windows XP, download M$'s TweakUI powertoy from here.
Thomas
Re: Edit registry!
Run regedit and do a search for Packard Bell this should point you to wherever they have things.
Don't forget to make a backup of your registry first though.
Click on file then export to send a copy of the registry to a safe place.
A double click on the saved file will then restore it if it all goes wrong.
Good luck
This works for win2k from dos
Rundll32 IedkCS32.dll,BrandCleanInstallStubs
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
can't u just delete the "signup" folder (probably in C:/Program Files/Internet Explorer/SIGNUP/)?
Re: IE & OE Taskbar logo's!
This worked for me:
    rundll32 iedkcs32.dll,Clear
Failing that try and find the icon in the PB folder, copy it and rename the icon picture file as 'old file'. Open the copied icon file and alter it to your own taste then rename it as the original file.
You do all this at your own risk though because what works for one may or may not work for another. .
Thank's all, I have sorted it!
Regards
Mike
Do tell what was the cure?
Well, powertoys for Windows XP did the trick and was the easy option.
See the message above from Kuglin!
Regards
Mike
Glad I could help. Smiley Some of those Powertoys are pretty cool, though not too many people know about them. Cool
Thomas
