I bet I've missed something simple
When I select "Restart" my PC doesn't, it just shut's down and waits to be manually started again, prior to installing XP it used to restart automatically.
I've probably changed a setting somewhere, but can't see where, or maybe Tweak XP2 (with XP magazine a couple of months ago ) had something to do with it, but again I can't see what...
Any offers please?
I have w2k - and I seem to recall that I needed to enable 'Advanced Power management support' in Control Panel | Power Options | APM' - so probably something similar in XP.
I have that problem with a K75SA motherboard.
Tried the power management setup - didn't make any difference.
Traced it to a non-powered USB hub plugged in to the on-board USB port, once removed all was ok, although it takes quite a while to shutdown. Further investigation found that any PC powered USB ( modem etc) device that wasn't unplugged would stop the pc shutting down.
If you are having the same problem and can't re-arrange your USB stuff, just press & hold the off button ( for a few seconds) when windows says it's shutting down.
Jeff
soung gd to be work...just press the shutdown button on the case.
but make sure just save all the work b4 u doing so.
u know when the data is corrupt or not there.there wont be any help..
It's worth noting that some PC's need to have their power management options turned on in the Bios, as well as in Windows.
