Huge speed increase with Speedtouch 330 driver update
Okay I know it should be obvious but for some reason it didn't occur to me to update my Speedtouch 330 modem drivers after I was Maxed.
Previously on 2Mbps before Max, I now have a stable rate of 7000 but my downloads were consistently maxing out at 2.6 Mbps. I've just installed the latest modem drivers from www.speedtouch.co.uk and at a stroke my speed has jumped up to 5.2 Mbps!
So, anyone with speeds lower than they expect might benefit from a driver update Wink
was that the high speed driver zipfile (PPPoA_0-38_ISO_MODE.zip) ?
Yes that's right. I also ran the TCP Optimser from here, but it didn't make any appreciable difference to the download rate.
One or the other of these tweaks has however reduced my maximum ping times to l8nc.com from ~100m/s to around 60m/s, although the average is still stuck at 55m/s :?
'k thanks. someone gave me a 330 ages ago but i never installed it as my V105 seemed good enough ... now i'm on maxdsl i might give it a go
