How to turn off laptop wifi?
aeroalfie
Hello i know this is in the wrong section but i need a quick reply - im going away a dinner time and taking the laptop with me, i will be running of the battery & wont have internet connection so i don't need my laptop wifi turned on . I have been looking through the settings but cant seem to find any option to completely turn off wifi?
Laptop is a Dell Inspiron 1501 running vista basic.
Any help much appreciated.
Plusnet Staff
Plusnet Staff
Fixes: 159
Not used Vista much myself, is there a network settings sections where you can right click on the wireless icon and disable it?
 Chris Parr
 Plusnet Staff
aeroalfie
Hello Chris, there is a 'network and sharing center' but i only seem able to disconnect from my home network - while the laptop wireless stays on scanning for other networks. Sad
EDIT: found it - the option is in 'Windows Mobility Center' what a strange place to have this option when there is a network and sharing center :?
cheers Cool
Nick_Russell
I think on Dell laptops you toggle WiFi on and off with F2 function key.
Some laptops have symbols above the F-keys which control things like contrast, brightness, volume, display output and wireless.
The F-keys on their own usually control what they would with applications, but laptops usually have an extra 'Fn' key often to the left of the spacebar.
I don't know Dells that well, but if there is an icon which looks like a wireless one then try holding down the Fn key with the appropriate F-key.
Others have an separate button or switch.
Also I think we've been between disabling in hardware or via Windows. I would assume disabling in hardware is more efficient on the battery, but I don't know.
Re: How to turn off laptop wifi?
Computers and Hardware, would be more appropriate, so I will move it across now.
Jonathan
aka Chilly
