How does one set-up a Sagem Modem to SuSE 9.1 Pro
How would I go about setting up my Sagem USB Modem F@ST800 to SuSE 9.1 Pro, someone from suse's forum had SuSE 9.0 Pro and a Sagem F@ST800 which you would think it was the same, well it ain't. I have the Linux Driver for the Sagem but it must be installed manually. Has anyone had the same problem as I, is there any documation on how to set-up the Modem to SuSE, would appreciate it. Thank you.
Regards
James_the_Great
1 REPLY
You are more likely to get a better reply on a Suse or Linux forum than here.
For future compatibility I would recommend ditching the USB modem and going for an Ethernet modem/router connected to a network card on SuSe.
