How do I open a Flowpoint router?
I have an old BT-issued Flowpoint 2210 router. It's getting a bit long in the tooth and I suspect some parts of its power supply might be dying, especially with the hot weather.
The question is, how do I get inside it? There are no visible screws, rivets, etc.
BT, of course, have discontinued it and refuse to believe it ever existed.
LeX
Anything hidden under labels etc. :?:
I've quite often found that to be the case when you can't find any way in.
Also I've moved this topic to the Computers and Harware as its really hardware related.
Dont forget it is still owned by BT and making any modifications is not permitted, if you cancel your ADSL subscription (assuming you are still on BT installed) they might ask for it back and might require you to pay should they not be happy with any changes you have made.
Chris
I'm not worried about BT, they don't believe it ever existed!
And I've just found the screws - underneath the feet! But not all of them, and I didn't take all four off to look!
Thanks anyway
LeX
(feeling rather foolish!)
