How do I connect to my System at home from a remote computer
Now that I'm connected 24/7 at home now on ADSL how can I access my files on my home computer from a remote computer?
the_norris
Hi
If you could post some details of your setup, then people could help. Eg Windows?? - connected via ?? router, usb modem etc.
Also what are you connecting to your PC todo? VNC (Remote controll) FTP server, web server etc.
Phil
VNC is a popular option, but also you can use programs such as Remote Anything.
Like VNC, this has a slave running on the PC you want to access and using the master program, you can access it remotely - View the screen, control the cursor, take screenshots, send messages, shut down etc.
If you have XP pro you can enable Remote desktop which is like VNC but a lot better Smiley
It is under Remote tab on the my computer properties.
Thanks to everyone who responded, Basically I just want to get access to my files on my harddrive. I'm running XP pro so I think I will try setting up the remote desktop failing that go for the other option of a third party connection program like remote anything, Thanks once again
Shaun Smiley
if u just want the files, then set up an FTPd ( i would recomend GuildFTPd from www.guildftpd.com as it is free and really good) This will allow you to upload and download your files without the need for a desktop so it is faster Smiley
Buz
