How change reg key?
henderson1977
How change reg key?
Hi all
I am working on a project to roll-out XP SP2 to 1500+ machines firmwide. I am currently trying to change the default Windows Sound Scheme to the No Sound Scheme. I have found the existing reg key that I need to alter:-
HKCU\AppEvents\Schemes - (Default)
(Default) is currently set to ".current" and I want to change it to ".none" via a GuiRunOnce script.
So far I have tried:-
reg add "HKCU\AppEvents\Schemes" /v (Default) /t REG_SZ /d .none /f
However, this just adds another (Default) key with the .none value, so now I have 2 (Default) keys. All I want to do is change the existing reg key from .current to .none.
I have also tried to delete the existing key first by using:-
reg delete "HKCU\AppEvents\Schemes" /v (Default) /f
... but I get the error:-
Error: The system was unable to find the specified registry key or value
Any ideas anyone plz?
Cheers
Scott
henderson1977
How change reg key?
... think I've found it now guys...
reg add "HKCU\AppEvents\Schemes" /v "" /t REG_SZ /d .none /f
FireStorm
How change reg key?
Just for your info i did a project at work to upgrade everyone to SP2.. Take a look a WSUS server.. its fantasticly easy.. quick change to you AD group policys and everyone gets it :-D
