Help!!!
Help!!!
Well, did an unintall of exeem & kazaa lite tonight and since then web browsing has dropped to dialup speeds.
However, direct downloads are still full 1 meg speed...but browsing is down to a crawl...anyone know why this might be?!?
Denzil
Help!!!
These file sharing things seem to be notorious for letting in trojans and spyware. Maybe there is something nasty using up your bandwidth. There are plenty of downloadable tools to deal with them.
Help!!!
i'd suggest you run spybot search & destroy and adaware and see what they pick up.
there is a tool called kazaabegone that i downloaded, but i have not installed it on anybody's computer yet. sounds like the tool you need, but the other spy and adware programs will find other stuff.
Help!!!
I've run NAV2005, Spybot, Adaware and nothing has been detected, I run them about once a week as it is so there is a slim chance anything could get through.
MarkAngel
Help!!!
Also try Microsoft's Antispyware, on Deep scan, that often finds things the others dont.
M :roll:
