Help on Qmail
Help on Qmail
Hi Folks
Anyone out there familiar enough with "Qmail" able to explain how to add a message ID that will get through Plusnets anti-spam block? I have established that some legitimate email is not getting through to me,because of Qmails apparently complicated way of not including a message ID
Thanks Ian & Linda Jordan
Moderators note (John) Title altered so that it relates to some subject. Just putting the word help is giving nobody a clue as to what you want help with and would tend to make people ignore it.
Help on Qmail
Are you running your own SMTP mail server, i.e. on your own PC?
The blocking occurs on incoming mail to PLusNet's mail servers so it is the sender of the mail (or some mail server between them and you) that is not adding the Message-ID and there is nothing you can do about it as the receiver of the mail.
Or have I not understood what you are asking?
Help on Qmail
No you understood perfectly.I am probably going to get an answer I don't understand here;but is it possable for the person to by-pass the Plusnet server,and send e-mails directly to my computer IP address without my setting up a mail server?
And John...... I will consider myself severly chastised :-(
Ian & Linda Jordan
Help on Qmail
You cannot send email to an IP address, it has to go through the PlusNet mail servers because that is how mail is distributed around the internet.
The only way you are going to get the email is if the sender has the Message-ID added and they must query this with their ISP. There is nothing you can do but inform the sender to make such an enquiry with their ISP. Note: Many other ISPs are rejecting mail without a Message-ID so it is not just PlusNet they would have problems with so it's in their own interest to get it sorted at their end.
Help on Qmail
Help on Qmail
Sorry about that,pressed "submit" instead of "preview" but I had an idea that was the most likely reply:but thanks anyway
Ian & Linda Jordan
