Help With Wireless Network
trexalan
Just to give you some back ground info first.
Just got a new laptop Spec http://uk.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/selected_product_option.jsp?service=UK&PRO...
Home Desktop Here:-
MB ABIT NF7-S V2.0
AMD 2800XP
512 Corsair ddr ram
160 gig hd sata
40 gig hd ide
64 mb geforce 4
Sorry if the desktops a bit non discript (built it myself)
Belkin Adsl modem with with wireless-g router Spec http://catalog.belkin.com/IWCatProductPage.process?Merchant_Id=&Section_Id=201576&pcount=&Product_Id...
Also Belkin Wireless G USB Network Adapter Spec http://catalog.belkin.com/IWCatProductPage.process?Merchant_Id=&Section_Id=201576&pcount=&Product_Id...
New laptop connects to the internet via the router.
Desktop connects to the internet via the usb adapter
So this is the problem,
The Laptop cant see the desktop & vice versa.
Ive tried setting it up one or five different ways, read the tutorials but just not getting it , Gotta say this is pritty deep for me never tried networking before so it could be one of a million things.
Anymore info req. give us a shout.
Cheers Phil...........
Have we got your network configuration correct?
Laptop connects wirelessly to router using DHCP
Desktop connects wirelessly to router via USB wireless adapter, using DHCP.
The answer to your problem kinda depends what you mean by "the laptop can't see the desktop"
If it can't ping the desktop, then it's a routing problem. If it can't see the desktop in Windows Network Browsing (which is what I think you mean), then it's probably a domain/workgroup issue. What operating systems are the two machines running?
trexalan
Laptop: XP Home sp2
Desktop: XP Pro sp2
