Help! I need someone with a floppy drive
Stupid problem, my laptop des not have a floppy drive and I am trying to connect it to a small network. All goes fine until I try to make a set up disk for the other computors on the net, you do not seem to be able to send the file to cd.
any ideas?
Is it possible for some one to make a floppy and then email it to me or will that not work?
You could always make the changes manually, or purchase a usb floppy drive for about £20.
Chris
Thanks, are the many changes that need to be made?
It depends on the setup, if you describe what you are connecting to eg a router, direct to another PC or a hub etc and what IP addresses you are using - an internal range 10.x.x.x or 192 or 172 addresses or using a block of IP addresses etc.
Chris
Yeah thanks, I think I'll try to find a floppy drive, it sounds more like my level.
Thank for your help.
