Has anybody....
Has anybody....
...had any experience of using Powerquest Drive Image 7?
Has anybody....
ive heard of it, ive probably used it, does it come with powerquest partition magic ?
if it does i have, and its worked fine, if not power quest do some gerat products so i would say its pretty good, i would wait for more response though Smiley
yours truly
marc
Has anybody....
yours truly
marc
No it doesn't, it is usually sold as a stand alone program. I've not used Drive Image, but the reviews in the PC magazines are very favourable.
Partition Magic usually ships with Boot Magic.
Has anybody....
Thanks for these. I'm really interested in knowing if it's compatible with a RAID 0 setup. Mine requires a small driver file to be automatically loaded on Windows startup to get the RAID configuration to start.... so would the disaster recovery boot-CD not be able to recover the system if that file couldn't be loaded? (ie if the RAID configuration wasn't initiated?).
Has anybody....
TBH I don't know, but you should be able to find out from www.powerquest.com. There's a link at the bottom of the page for "contact us" and they should be able to help you.
Regards
