Hard-Drive?
Hard-Drive?
How can i find out the speed of my hard-drive 5400/7200??
Thanks, Wink
[Moderators note (by Thomas): This is a question about computers and hardware, so I have placed it in the Computers and Hardware forum.]
zpeterk
Hard-Drive?
Go to the manufacturers web site
Hard-Drive?
You need to find the make & model number then visit the manufacturers website and search for the model number.
You may need to remove the drive to find the initial info - I don't have a util that will tell you this info but it's possible the WIndows Device Manager will.
If I find something else I will post a link.
Hard-Drive?
sis soft Sandra will tell you what hard drives you have (thus removing the need to take one out)
most hard drives are 7200 unless laptop drives or raptors
Hard-Drive?
Well in device manager it says WDC WD200BB-00CVB0 if anyone could find the spped would be appreciated, i think its a western digital
Thanks, Wink
Hard-Drive?
Western Digital Caviar WD2000BB-Hard Drive-200GB-standard-3.5""-ATA-100-7200RPM-2 MB
Hard-Drive?
sorry about that, just realised it's the wrong one. should be 7,200 though yours, is it a 20GB?
Ken
Hard-Drive?
Yep, 20GB
Thanks, Wink
Hard-Drive?
All this tells you is how fast it goes round it says nothing of you data transfer rate dma etc.
Hard-Drive?
