HP Laserjet 1100 printer
shermans
Does anyone have any solutions for multipage misfeeds on a HP Laserjet 1100 ? I know that this is a common fault and I have seen many topics on the problem mentioned on the net.
Having got fed up with the constant misfeeds, often drawing five or six pieces of paper through at the same time, I eventually stripped the printer down to its bare components, bought new rollers, feed pads and separator pads - every single roller got changed " - and re-built it. But it was no better. So I went and bought HP paper for it, but even that misfeeds. I never have any trouble with my old faithful NEC, but the cartridges have just got too expensive, so I have to use the HP.
Anyone know of a fix for this problem ?
1 REPLY
shermans
Problem solved.
I had left out a spring from the feeder pad !! Shockedops: Normally, it is screws which are left over, not springs and in fact, I never found the spring and had to replace it.
