Graphics
Graphics
Does anyone know of any good gaphics editors.
[Moderators note (by Thomas): Post moved to a more suitable location.
Graphics
Paintshop Pro
or
Photoshop
Porably the best two on the parket at the time, with photoshop being the better one.
Graphics
And don't forget, for those with £400+ to spend, that there's also Photoshop Elemtents, which is pretty good IMHO.
Thomas
Graphics
You mean for those who don't have £400+ to spend? Elements is the cheaper option Smiley
Graphics
Lol, yes that's what I meant. :roll:
Thomas
Graphics
like all things you must decided what you want to do with the software. Many of the good ones like paintshop pro you can get a sharewear version first to see if it does what you want.
Each package has its good points and bad points so its a matter of making a list of what you will use it for and then getting the software that matchs that.
