Got the pc back but a slight problem
Right got my pc back yeah. I was ment to install windows on it but when i hucked it back up windows was already on. I though ok. But ltr to find out the 1gig ram i am ment to have in there is actually 512ddr. There is 2 512 sticks in but there acting as 256 ones. Any idea why
remove one stick, see if its acting in DDR mode or somthing (to see if it is seeing ONE stick or both but at lesser values.)
if it is in DDR mode, you wil have to put the ram in dimm1 and dimm3 to make it work
I took one out and then it said i had 256 ddr ram. I will try what you said but the other 2 ram slots are for dual ram. Tried it and nothing werid really.
Here is what it says at the start
http://tinypic.com/29byxh
Also this is what crucial scanner picks up
http://tinypic.com/29d004
No probs now fixed it. I had to update the bios via live update
You have the msi neo 2 dont you?
Make sure your bios is set to default settings before using live update. Also after doing the latest bios update you may find one of your ps2 ports dosent work, well thats what happened to me anyway. :roll:
Well everything is a ok so far. Thanks for the advice
