Gigabit NIC for SBS Server 2003
Any ideas of a good gigabit NIC for SBS Server 2003.
Was recommended a Netgear GIGABIT NIC however the drivers caused the server not too boot, even after multiple re-installs tried different PCI slots but to no avail.
If anyone has one working, I would love to hear from you.
any intel one should not see you wrong
madswitcher
Hi rileymclaren
I use the Edimax NICs got them off Ebay - I think they use the RealTek chip set - but I have used about 15 or so and only had one minor problem. Used them on a variety of Windows and Linux machine and would recommend them.
Kind regards, Mike
Hi Mike,
Many thanks, have been researching the Intel ones but will check fleabay for Edimax.
Stevee
