Ghost
zpeterk
Ghost
I have a A7N8x delux motherboard which has raid, I use two sata drives mirrored and now after constant unplugging by my 18month old boy it will not rebuild the raid set. I thought I would ghost the remaining disk to a maxtor external firewire disc but it doesn't seem to whan to boot from the virtual partion although it will from the ghost floppy then it won't recognise the maxtor external disk. Is there any know problems with raid and ghost?
1 REPLY
zpeterk
Ghost
I found the answer! Its down to Symantec, you must run live update and then confirm that you are on version 2003.789 or higher and then attached device drivers found here from symantec
