Front Side Bus
Front Side Bus
Anyone know of a way of finding out a processor's FSB from within Windows?
P4 standard and Xeon processors in multiple machines.
Chris
Front Side Bus
Front Side Bus
Cheers Peter, thats just what I needed.
Chris
Front Side Bus
Another quick question (i'll keep it here cos its semi relevent) -
I've got a server with a single xeon 2.2gig processer, the server will take 2 processors, however I can only seem to find 2.4 and above. Anyone got any experience of using two different speed processors? Both have the same bus speed and cache size.
If the second only runs at 2.2 gig then that is fine.
Chris
Front Side Bus
scrap that, a bit more looking and ive found the processor i need.
Front Side Bus
Just to clear it up, you can not run 2 diff CPUs, they have to be identical.
Buz
