Floppy Drive Problems
Fixes: 132
Hi
Back in the summer when I upgraded my PC with two new hard drives I decided to disconnect the floppy drive completely. The power supply from the floppy then was used to power the 'break-out' box for the Audigy card.
I now need to re-install XP and require the floppy for certain hardware drivers during installation but cannot get the floppy drive to work. Initially I connected the data cable the wrong way and the light went on continuously but the drive was not shoing in My Computer. Now, with the cable the correct way round still the floppy drive is not showing.
I have checked that the FDD is Enabled in BIOS and a floppy driver seems to installed as in Device Manager.
Two questions:
What have I missed?
or
How can I make a bootable CD adding the drivers to it so that when I press F6 at the start of XP installation the Bootable CD can be used rather than a floppy?
Cheers
P.S. I did read the earlier posts regarding making Bootable CDs but these all assume that you have floppy drive first.
Forum Moderator and Customer
its called slipstreaming ..
http://maximumpc.com/2005/01/how_to_slipstre.html
will show you how.
Fixes: 132
Thanks for the link.
Never done anything like this before but it seems straight forward once you have read it through.
My copy of XP already includes SP2 so that's one step less.
All I need to do is add the drivers for my Silicon Image PCI IDE card as detailed and that's it - right?
So, instead of pressing F6 at the start of installation and waiting for the prompt to insert the floppy, all drivers for the PCI card will automatically be loaded without intervention?
I'll read through it all again later and give it a go.
