FTP IP Address
FTP IP Address
I have just installed a trial of WebcamXP pro.
The FTP address setting does not allow for 'ftp.plus.net' to be input; It requried an ip address (xxx.xxx.xxx.xxx).
I've been unable to find an IP Address alternative.
Does anyone know the IP address for FTP'ing to Plus Net?
FTP IP Address
ftp.plus.net resolves to 212.159.9.131
FTP IP Address
If you want to find an IP address for a domain just try the ping command at a dos/cmd prompt.
C:\Documents and Settings\Peter\Desktop>ping ftp.plus.net
Pinging ftp.plus.net [212.159.9.131] with 32 bytes of data:
Reply from 212.159.9.131: bytes=32 time=23ms TTL=249
Reply from 212.159.9.131: bytes=32 time=101ms TTL=249
Reply from 212.159.9.131: bytes=32 time=122ms TTL=249
Reply from 212.159.9.131: bytes=32 time=144ms TTL=249
Ping statistics for 212.159.9.131:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 23ms, Maximum = 144ms, Average = 97ms
Cheers
Peter Cool
Thanks for the quick reply!
Much appreciated.
Kind regards
Stuart
Good Tip
Been using Ping ealier today.
Why didn't I thnik of that!!!!
Wink
