External Modem
External Modem
I would like to buy an external V90 data/fax modem for use alongside my Plusnet 512 ADSL connection. It will be used as a backup connection and to receive and STORE faxes when the computer is both on and off. One problem I have with my laptop is that it does not have a 9 pin serial connection. It does have a parallel, Firewire, USB and PCMCIA ports
My friends in France have such a modem that is made, I believe, by a company called Olitech.
Can anyone offer advice as to where I can purchase such a modem?
External Modem
It will be the Self memory USB V92 unit you'll be looking for. It has 4mb memory for storage of Faxes & Voicemail when PC isn't on.
Olitec UK , 3 Comet House, Calleva Park, Aldermaston, Berks, RG7 8JA
Tel: 0800 028 4516 Fax: 0870 458 0119
Email: uk@olitec.com
http://www.olitec.com/
UK sellers are listed on the website if you delve around a bit.
External Modem
Many thanks for the fast reply. I will delve.
David
External Modem
See my reply in http://portal.plus.net/central/forums/viewtopic.php?t=13195&highlight= which is another thread asking for an external voice/fax modem.
