Excel file transfer from MS Office 2000 Pro to Windows XP
All the Excel files transferred from my old computer operating under Windows 98 and using MS Office 2000 Professional appear under Windows XP in code format. Is there a means of turning this information into normal text?.
MarkAngel
As long as at least that version of Office that was installed on the old machine is installed on the XP machine you shouldnt have any problems :?
Check that the file extensions on the files is intact, but it sounds like they may be possibly corrupted Sad Do you sill have access to the old data to get a new copy?
M
Thanks for the advice. I have made a new copy and have managed to transfer the files succesfully.
