Errors following Windows Update...
:?: Does anyone else have error messages since carrying out windows update this week? I have Windows XP Media Centre Edition on both my laptop and desktop.
I installed the updates on my desktop, and found the error messages after restarting. Thought it must be something wrong with the machine, but since installing the update on my laptop it now has the same errors... coincidence?
Error message says:
The system DLL user32.dll was relocated in memory. The application will not run properly. The relocation occured because the DLL C:\windows\system32\HHCTRL.OCX occupied an address range reserved for windows system DLL's. The vendor supplying the DLL should be contacted for a new DLL.
Is anyone able to help me fix this? I'm not a computer whizz, so laymans terms would be appreciated Smiley
Should I contact Microsoft? If so, how?
Thanks for reading. :?
Cloudmaster
See if this link helps
Many thanks!
Just found that link in another forum. It has solved the problem. Thanks again for helping. Cheesy Cheesy Cheesy
