Error when windows XP starts
I get this error when windows xp boots into the desktop, you know just before on the blue screen, i get this box that says Yes,No and with a exclamation mark in the top left corner but no error code so its makin things difficult, if i click No, it carrys on into my desktop and boots ok, its just the fact i keep gettin this annoying error of some kind? anyone help??
Thanks, Wink
Have you checked your machine for viruses etc.
What happens if you click yes?
If you press F8 during boot, you can select a boot up which logs your machines startup, it creates a text file called bootlog.txt
You could try running hijackthis to see if you've got any strange entries in your windows startup list.
If i press yes it does the same thing, just carries on into windows xp, i have run my computer with the AVG anti virus program and it find nothing, I haven't tried hijackthis though.Huh
try hijack this, it could be your anti-virus software as well
Post your hijack this output here.
You could try removing AVG as its well known for causing the problem you describe
It could be AVG, it's know to post virus warning messages during load up. Get a better virus checker anyway, like NOD32 or Kaspersky (4.5)
