Error after 'booting up'
Midville
Once XP has booted up a get the following error message:
WJView Error
ERROR: could not locate Java virtual machine. Class not registered.
I have try to find files to unistall, but no joy.
Any ideas out there.....
Jason
Try Start - Run - then enter msconfig in the box that appears.
You will then get the option to alter what the machine boots up with.
Look under startup and also under services and see if its mentioned there.
If so untick and reboot.
Midville
Nope its not there Sad
Midville
using regedit, i find this c:\WINDOWS\system32\wjview.exe.
Do you think its safe to 'bin it'.
Is ths the microsoft java thing which is no longer used?!?
Thanks in advance.
Jason
Back up the registry first before you bin it and then if there are problems you can always go back to it.
you could download the Jave 2 environment and this *should* fix it, however it is safe to delete that file
