Equivalent of cron jobs in windows?
michaelscott
I'd like to be able to run a PHP script every 5 minutes - obviously i can't be at my computer all day and night to set the script off. Is there a way to do this in a similar way to unix cron jobs?
BTW, don't suggest using a refresh tag to make the browser reload every 5 mins - I don't want to have to leave the browser open.
Thanks,
Mike
Is Windows task scheduler no use? I don't use it but the folder is in Control Panel on my Win2k system.
michaelscott
No. It won't let me execute a script and it won't let you run something as frequently as every 5 minutes.
I run scripts fine on scheduler all the time.
Both console based Tcl, PHP, Batch and VB.
The best method is to use a Batch file to launch the needed actions. You call this, and does the work of changing dir and calling PHP where needed.
Add a task as normal. Use any old properties, as you need to manualy edit it anyhow.
Schedual task: Daily
Start time: 09:00am
Echedual daily task every: 1 days
Click the advanced button
Repeat task every "5" "minutes"
Duration: "23" hours, "59" minutes
In the setting Tab.
Enable the "Stop the task if it runs for:"
I suggest 4 mins
This will make sure the task is killed off, to allow the next 5 min cycle to occur. If the task is still running when the next cycle is due, launch is skipped.
I could likely find a program that will parse and run crontab style files.
michaelscott
thanks. i've just had a play and it can do everything i want Cheesy
