Email to PDA
Email to PDA
Has anyone used a Compaq iPaq and Nokia 6310i to download plusnet e-mail?
Can it be done?
Email to PDA
I don't use the same stuff as you, but it can certainly be done.
I'll be able to give you more accurate help though (presuming you're having a problem and not just making a general enquiry) if you give more details!
Thomas
Email to PDA
It was just an initial enquiry. Are there any instructions on how to do it anywhere?
Email to PDA
Not really... how do you intend to connect? Cable, IR or BT? And what model iPaq do you have? Depending on what your response, it will either be very very easy to set up or quite headache-causing. Wink
Thomas
Email to PDA
I have a Compaq Ipaq 3970 running PocketPC vers. 3.0.11171
I intend to conect using bluetooth and my nokia 6310i
Email to PDA
In that case you should have no problems... the iPaq's internal BT software should connect to your phone and create a DUN (dial-up networking) connection for you with no problems.
Thomas
