Email (outlook)
Email (outlook)
Hello
not sure if any of you can help
on outlook express i was able to click a link in any email to open it but its not working now can anyone tel me how to enable it again
Email (outlook)
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q281679&sd=tech
Also lots of suggestions to try if you google for 'can't click links in outlook express'
Also check under IE tools -> internet options -> programs that OE is your email client.
Fixes: 57
Email (outlook)
mine only works with double click
Email (outlook)
thanks for the info a double click wont work , strange it was workin a few days ago
Fixes: 57
Email (outlook)
Have you changed your mouse driver or software
Fixes: 57
Email (outlook)
