Duplicate files
Fixes: 133
Duplicate files
Hi
With the many (1000s) of photo & video files I have collected over the years and transfered from PC to PC, renamed, etc. I am sure I have duplicates all over the place. Although time-consuming it is a little easier to find duplactes of the same length and same name using the standard Windows search function.
What isn't so easy is finding duplicates where the contents of the file are the same but the fiole names are different. Is there a program that can easily automate this process as I am sure I can free up lots of space?
Cheers
Forum Moderator and Customer
Duplicate files
You need a duplicate file finder try
http://www.tucows.com/preview/373411
for a free one or a trial like
http://noclone.net/
If you google for duplicate file finder there are loads of them some free and some cheap ones.
Fixes: 133
Duplicate files
Thanks.
I had previously downloaded a Duplicate file finder from a Goggle search but it seemed overly complicated and I was unsure about whether to trust it.
I will look at the Tocows recommendation.
Cheers.
