Dumb question time
Dumb question time
Hi All
I am using a D-link DI-614+ but I imagine my query applies to most routers.
If I change something ie a setting in the firewall and click apply is that sufficient or is it necessary to reboot the router.
Also is there a way to confirm if a computer is in the DMZ or not as I am not sure if my attempts to put this machine temporarily into the DMZ are successful or not.
Thanks in advance
Re: Dumb question time
It really depends on the router, I use the Netgear DG834, and if I click apply on rules to allow traffic, this is normally enough but when I revoke them I normally find I need to reboot the router.
Use the GRC site to check if a computer is correctly working within the DMZ.
I think the DMZ has worked went to the above site, and whereas before most ports were stealthed with a couple closed the situation is now reversed which I presume is what is supposed to happen so security does not seem to have been compromised too much, and am hoping that the fact I am using a "Mac" may improve the situation somewhat.
Thanks Aaron for the reply it is appreciated
