Does anyone know the settings for a modem?
Can you give me the correct settings to set up my modem speedtouch 576. I have contacted speedtouch and they told me to ask my isp.
1. Is the connection a routed ppp or bridge connection?
2. What is the vpi/vci setting?
3. What is the connection type, PPP over ATM (PPPoA) or PPP over Ethernet (PPPoE)
Moderators note by John (johnessex) Topic moved to a more apt part of the forums.
1 REPLY
Hi there the seetings you need are:
1. Routed PPP
2. VPI = 0, VCI = 38
3. PPPoA
Hope this helps, if you have any more problems don't hesitate to ask!
