Dial up or router?
Dial up or router?
Hi :lol:
I am new to plus net so if I am in the wrong forum please tell me?
I have a Packard Bell desktop PC under a year old 2.8 Ghz 512 ram using a Voyager 105 usb adsl modem on broadband.
I want to be able to use my Dell 15160 Laptop also 2.8 Ghz
but it has a 56k dial up modem.
Q Can I use it with my existing plusnet software asa dial up?
or Q2 do I need to buy a router and if so what spec do I need for plusnet to work on it and make life simple? :?:
Any advice appeciated
Ernie
[Moderators note by Thomas (kuglin): CAPS removed from title, as they're akin to shouting - and hard to read!]
Dial up or router?
You have a couple of options and a router is indeed one of them, you can get them pretty cheaply. The alternative to a router is to share the internet connections through your PC using Internet Connection Sharing.
To do this you would have to connect your laptop to your desktop with a crossover cable.The dissadvantage of this is that the desktop PC would have to be switched on in order for the laptop to connect to the internet.
Dial up or router?
ICS is evul so thats out the window
What you would want is a 2 or 4 port ADSL router (with built in modem) with uses ethernet cables to conenct your PC and laptop to it. This will allow both , or either PC to be on at the same time and both to have axx to the net independant of each other. You may want to get a wireless router so that you can equip ur laptop with a wireless card (I recomend Buffalo or Linksys) so that you can wander about your house wiht the laptop and not need a long cable.
Buz
Dial up or router?
ICS is evul so thats out the window...
Well there is that.... :lol:
router or dial up?
Thanks for replies.
Ernie
