Device confilct
Andrew
Device confilct
:x This has been driving me nuts for days! I've developed a conflict when VMM tries to load Vnetbios on startup. The only thing I can think of that may have caused this is run some old PC games (from Plusnet), Arakniod, Galaxian and Soi (showing my age now!) - one of them screwed up my display for a while and the conflict seems to stem from after this.
I am running Windows 98, with a 3Com NIC (which now doesn't work), I've reinstalled the network drivers and tried to resetup my network but I keep getting the same problem. Has anyone got any ideas please?
Device confilct
This is for win me but it should give you a good idea on the problem
Microsoft Knowledge Base Article - 273738
Comments?
Provide us with feedback on this article
Support Centers
Windows Millennium Edition
Other Support Options
Contact Microsoft
Phone Numbers, Support Options and Pricing, Online Help, and more.
Customer Service
For non-technical assistance with product purchases, subscriptions, online services, events, training courses, corporate sales, piracy issues, and more.
Newsgroups
Pose a question to other users. Discussion groups and Forums about specific Microsoft products, technologies, and services.
Page Options
Send
Print
How to Troubleshoot Windows Millennium Edition Startup Problems
View products that this article applies to.
This article was previously published under Q273738
If this article does not describe the error message that you are receiving, view the following Microsoft Knowledge Base article to view more articles that describe error messages:
315854 Windows 98 and Windows Me Error Message Resource Center
SUMMARY
This article describes how to troubleshoot problems with your computer if it stops responding (hangs) or if you receive either a "fatal exception" or "invalid VxD" error message.
MORE INFORMATION
To troubleshoot problems with your computer if it stops responding (hangs) or if you receive either a "fatal exception" or "invalid VxD" error message, use the System Information Utility tool (Msconfig.exe). After you restart your computer several times, this tool can help you isolate a specific file or registry key that is causing the problem. After you determine the specific file or registry key that is causing the problem, edit the appropriate file or registry key to remove the entry, and then return the System Configuration Utility tool to Normal Startup mode.
For additional information about how to perform a clean-start procedure in Windows Me by using the System Configuration Utility tool, click the article number below to view the article in the Microsoft Knowledge Base:
267288 How to Perform a Clean Boot in Windows Millennium Edition
The following topics are included in this article:
How to start Windows Me in Safe mode
Windows Me does not start in Safe mode
Windows Me starts in Safe mode
How to Start Windows Me in Safe Mode
If Windows Me does not start normally, try to start your computer in Safe mode. When you start Windows Me in Safe mode, many Windows Me device drivers are disabled and the standard VGA display driver is used.
To start Windows Me in Safe mode, press and hold down the CTRL key while you restart your computer, and then choose Safe Mode on the Windows Me Startup menu.
If your computer does not start in Safe mode, view the "Windows Me Does Not Start in Safe Mode" section of this article.
If Windows Me does start in Safe mode, view the "Windows Me Starts in Safe Mode" section of this article.
Any of the following conditions can prevent Windows Me from starting in Safe mode:
Your computer may be infected with a virus.For additional information about computer viruses, click the article number below to view the article in the Microsoft Knowledge Base:
129972 Description of Computer Viruses
The complementary metal oxide semiconductor (CMOS) settings for your computer may be incorrect.
Verify that your CMOS settings are correct. Note that you may need to contact the computer manufacturer to verify these settings.
There may be a hardware conflict on your computer. Hardware conflicts can include Peripheral Component Interconnect (PCI) basic input/output system (BIOS) settings, Interrupt Request (IRQ) conflicts, redundant communications (COM) ports (for example, two COM1 ports, or an internal modem that is set to the same COM port as an existing serial port), or a damaged memory module or chip.
You may need to change a setting in the Msdos.sys file. For example, the Logo setting should be zero (0).
For additional information about the Msdos.sys file, click the article number below to view the article in the Microsoft Knowledge Base:
118579 Contents of the Windows Msdos.sys File
If Windows Me still does not start in Safe mode, there may be a registry problem. To diagnose a registry problem, run the Windows Registry Checker tool (Scanreg.exe).
Restart your computer with the Startup disk in your floppy disk drive, and then choose the Minimal boot option.
Type scanreg /restore, and then press ENTER.
The Windows Registry Checker tool (Scanreg.exe) is not included on the Startup disk. When you start your computer with the Startup disk, the folder where the Windows Registry Checker tool is located (C:\Windows\Command) is added to the path. For additional information about the Windows Registry Checker tool, click the article number below to view the article in the Microsoft Knowledge Base:
183887 Description of the Windows Registry Checker Tool (Scanreg.exe)
For additional information about receiving an error message that your registry is damaged after you run the Windows Registry Checker tool, click the article number below to view the article in the Microsoft Knowledge Base:
186909 Registry Checker Continues to Detect Registry Damage
If Windows Me still does not start in Safe mode after you use the Windows Registry Checker tool, reinstall Windows Me in the same folder in which you originally installed it.
If you still cannot start Windows Me in Safe mode, install Windows Me in a new, empty folder. This is a troubleshooting step to help you determine if the problem is related to a remnant of the previous operating system, such as a configuration setting, or if the problem is a hardware problem.
When you start your computer in Safe Mode, the "Safe Mode Troubleshooter" Help topic is displayed. For additional information about how to use the Safe Mode Troubleshooter, click the article number below to view the article in the Microsoft Knowledge Base:
274155 Description of the Safe Mode Troubleshooter
If Windows Me does start in Safe mode, use the following procedure to see if any devices do not load correctly:
Click Start, click Run, type msconfig in the Open box, and then click OK.
Click Selective Startup.NOTE: The System Configuration Utility tool (Msconfig.exe) cannot disable a file that has the read-only attribute, although it behaves as though it can. To determine if the System Configuration Utility tool has replaced the file that you are trying to disable, open the file. If you see text similar to the following text at the beginning of the file, the System Configuration Utility tool did replace the file:
rem
rem *** DO NOT EDIT THIS FILE! ***
rem
rem This file was created by the System Configuration Utility as
rem a placeholder for your SYSTEM.INI file. Your actual
rem SYSTEM.INI file has been saved under the name SYSTEM.TSH.
rem
: The System Configuration Utility tool (Msconfig.exe) cannot disable a file that has the read-only attribute, although it behaves as though it can. To determine if the System Configuration Utility tool has replaced the file that you are trying to disable, open the file. If you see text similar to the following text at the beginning of the file, the System Configuration Utility tool did replace the file: The following chart describes four different boot options and which items each boot option verifies. To use a boot option, click to clear or select the appropriate check boxes for the specific boot options that are described in the following sections.
Prompt Boot A Boot B Boot C Boot D
Process System.ini file Yes No Yes Yes
Process Win.ini file No Yes Yes Yes
Load Static VxD Yes Yes No Yes
Load Startup group items Yes Yes Yes No
NOTE: If Windows Me does not start normally when you use any of the boot options, view the "Troubleshooting Protected-Mode Driver Problems" section in this article.
The Boot A Option
Start your computer by using the Boot A option. If Windows Me starts normally when you use the Boot A option, there is a problem in the Win.ini file. To find the line in the Win.ini file that is causing the problem:
Click Process Win.ini file on the General tab to restore the original file.
On the Win.ini tab, double-click the Windows folder.
Click to clear the load= check box, click to clear the run= check box, and then click OK.
When you are prompted to restart your computer, click Yes.
If Windows Me starts normally, there is a terminate-and-stay-resident (TSR) program that is loading from the run or load line in the Win.ini file that is causing the problem. Contact the manufacturer of the program for further assistance.
If Windows Me does not start normally when you use the Boot A option, try the Boot B option.
The Boot B Option
If Windows Me starts normally when you use the Boot B option, there is a problem with the System.ini file. The problem is most likely in the [386Enh] section of the original System.ini file.
To find the line in the System.ini file that is causing the problem:
Click Process System.ini file on the General tab to restore the original file.
Double-click the 386Enh folder on the System.ini tab.
Click to clear each check box that does not have a Windows flag next to it.
If Windows Me starts normally, there is a driver loading from the 386Enh folder that is causing the problem.
If Windows Me does not start normally, click to clear the remaining check boxes on the System.ini tab, one at a time, starting with the Boot folder. Restart your computer after you click to clear each check box. When the problem returns, the last check box that you selected is loading a driver that is preventing Windows Me from starting normally.
NOTE: If Windows Me starts normally after you click to clear the display.drv=pnpdrvr.drv check box, there is a problem with the display driver.
NOTE: When Adobe Type Manager (ATM) is installed, it modifies the SYSTEM.INI file by changing the SYSTEM.DRV line and adding a new line. For example:
[Boot]
SYSTEM.DRV=ATMSYS.DRV
ATM.SYSTEM.DRV=SYSTEM.DRV
For additional information about how to troubleshoot video problems, click the article number below to view the article in the Microsoft Knowledge Base:
127139 Troubleshooting Video Problems in Windows
If Windows Me does not start normally when you use the Boot B option, try the Boot C option.
The Boot C Option
If Windows Me starts normally when you use the Boot C option, there is a problem with a static virtual device driver (VxD) that is loaded from the following registry key:
HKEY_Local_Machine\System\CurrentControlSet\Services\VxD
To resolve this problem, view the "Troubleshooting Static VxD Problems" section in this article.
If Windows Me does not start normally when you use the Boot A, Boot B, or Boot C options, try the Boot D option.
The Boot D Option
If Windows Me starts normally when you use the Boot D option, there is a problem with a program that is run during startup. For information about how to resolve this problem, view the "Troubleshooting Startup Folder Problems" section in this article.
If you still cannot start Windows Me normally after you view the "Troubleshooting Startup Folder Problems" section in this article, view the "Troubleshooting Protected-Mode Driver Problems" section in this article.
The problem may be caused by a driver or VxD that is loaded from the registry. To determine if this is the cause of the problem:
Click Selective Startup, and then click to clear the Process Static VxDs check box.
Click OK, and then restart your computer when you are prompted.
If the problem is resolved, the problem static VxD is being loaded from the registry. To resolve this problem:
On the Static VxDs tab, click to select the first check box in the list.
If the problem is still resolved, repeat step 1 through step 3, but click to select the next check box on the Static VxDs tab.
When the problem returns, the last check box that you selected is loading the driver or TSR that is causing the problem. If the problem file is any of the following files, the problem is most likely with your network adapter:
Vnetsup.vxd
Ndis.vxd
Vnetbios.vxd
Vredir.vxd
Dfs.vxd
Vserver.vxd
Ndiswan.vxd
If the cause of the problem is your network adapter driver, contact the network adapter manufacturer and obtain a newer driver that works with Windows Me.
If the cause of the problem is a hardware conflict, view the "Troubleshooting Protected-Mode Driver Problems" section in this article.
The problem that you are having may be a result of a program that runs during startup. To determine which program is causing the problem:
Click the Startup tab, and then click to clear each check box.
If the problem is resolved:
On the Startup tab, click to select the first check box in the list.
If the problem is still resolved, repeat step 1 through step 3, but click to select the next check box in the list.
When the problem returns, the last check box that you selected is loading a program that is preventing Windows Me from starting normally. Contact the program manufacturer for further assistance.
The problem may be a Windows Me protected-mode driver. To determine if this is the case, follow these steps:
On the General tab, click Advanced.
In Settings, click to select the first check box.
Click OK, click OK, and then restart your computer.
If the problem is not resolved, repeat step 1 through step 4, but click to select the next check box in step 3. When the problem is resolved, the last check box that you selected is causing the problem. For additional information about advanced settings, click the article number below to view the article in the Microsoft Knowledge Base:
181966 System Configuration Utility Advanced Troubleshooting Settings
If the problem is not resolved, make PCI bus IRQ steering unavailable in Windows. For additional information about how to make PCI bus IRQ steering unavailable, click the article number below to view the article in the Microsoft Knowledge Base:
182628 How to Disable PCI Bus IRQ Steering in Windows
If the problem is not resolved, make devices unavailable in Device Manager:
Click Start, point to Settings, and then click Control Panel.
Double-click System.
On the Device Manager tab, make all devices under the following branches unavailable:
Display adapters
Floppy disk controllers
Hard disk controllers
Keyboard
Mouse
Network adapters
Ports
PCMCIA socket
SCSI controllers
Sound, video, and game controllers
To make a device unavailable in Device Manager:
Double-click the branch that contains the device that you want to disable, click the device, and then click Properties.
On the General tab, click to select the Disable In This Hardware Profile check box, and then click OK.
Restart your computer.
If the problem is resolved, make available the devices that you made unavailable, and then verify that that there are no conflicting devices.
NOTE: Make devices available in the following order:
COM ports
Other devices
To make a device available and check for possible conflicts:
On the General tab, click to clear the Disable In This Hardware Profile check box.
Click the Resources tab and verify that there are no conflicts listed in Conflicting Device List. Note that the Resources tab does not appear for each device.
Click OK, and then restart your computer.
If there is a problem with a device, view the following article in the Microsoft Knowledge Base:
133240 Troubleshooting Device Conflicts with Device Manager
For additional information about how to use the System Restore utility, click the article number below to view the article in the Microsoft Knowledge Base:
267951 Description of the System Restore Utility in Windows Millennium Edition
The information in this article applies to:
Microsoft Windows Millennium Edition
Last Reviewed: 12/17/2002 (1.0)
Keywords: kberrmsg kbFatalExErr0D kbFatalExErr0E kbhowto kbtshoot kbWinME KB273738
Contact Us
© 2004 Microsoft Corporation. All rights reserved. Terms of use Security & Privacy Accessibility
Andrew
Wow!
Thanks for all the info - the number of different "issues/solutions" makes me feel a bit less inadequate! I gave up trying to isolate the problem today and upgraded to XP (which runs on my laptop anyway) and everything is working fine again now.
