Defrag
zpeterk
Defrag
I have a laptop and it needs defragging, i has 25% free space with NTFS and 2K but defrag doesn,t seem to achieve anything anyone got any ideasHuh
Defrag
For XP use Start, All programs, Accessories, Disc cleanup this may remove some clutter, temp files and compress selected files. Possibly your temp files are taking up more space than you think.
Defrag is quite slow are you sure it finished working? If you cannot be sure that it works, then there are other defrag tools, look in "softpedia" for all sorts of tools which can be free, shareware, demo etc.
Defrag
What makes you think it needs defragged?
Is it running slow? If it is defragging generally won't speed it up too much.
zpeterk
Defrag
When you look at the analysis it's nearly all red
