DVD burning
zpeterk
DVD burning
Which program is best for changing avi files into dvd format so they can be burnt, i've tried using pinnacle studio but its not that sucessful. Any help is greatly appreciated
mossgrove
DVD burning
Roxio Easy CD and DVD creator v6 is good - it has a simple DVD menu editor included.
Other than that I use ULEAD DVD Factory for more detailed editing.
Tim
DVD burning
Nero burning rom I think can do what you want as well.
DVD burning
cce (cinema craft encoder)
www.doom9.org for a lot of good tutes and tools for doing what u want
DVD burning
if trying Nero6 its not in the standard package, but its a plugin you have to buy on top of it, ends up not worth it
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
DVD burning
Ulead DVD Factory, but it'll cost you.
