DVD burner crashes PC
chymorva
Help !!!
I've just bought a new DVD burner to replace my CD burner. Unfortunately this has the same problem as my CD burner had - when I try to do a CD to CD disc copy the PC crashes.
I use the bundled Nero Express software. When I click the CD copy button the PC resets itself just as though I have interrupted the power supply. I have changed the PSU to an uprated 550W dual fan to no effect.
Any suggestions would be most welcome as I'm tearing my hair out over this one.
TIA
holdtight
Hi, there is a patch nero supplied for these kind of symptoms, usually a dialogue box appears and redirects you when nero is run this is especially true of the bundled versions
if you havnt applied any updates or patches get them from Here making sure
you pick the correct version you are running
to find out open nero go to "help" then "about" and there will be your version
number
chymorva
Hi Bill,
Thanks for the suggestion. I updated to the latest version ( 6.6.0.8 ), however the fault remains the same Sad
