DVD Writer buying help
My CD/RW drive has finally died so I've decided to drag myself up to the next level of technology and get myself a DVD writer instead. :lol:
My question is, what is the best kind of writer to go for? I know it's an extremely open question but I'm a complete novice when it comes to DVDs.
All I will use it for is backing up my system to DVD, apart from that, I will burn audio "mix" cds to CDR.
Any advice?
I see from a quick scan of the net that you can get dual layer writers now. I assume that just means more storageHuh
Sorry if I sound a complete novice with this, I'm just a little out of the loop!!! :lol:
Cheers,
Tim.
You may as well go for a dual layer writer, seeing as they're only a few quid more. I can recommend the NEC-ND3500. Dual layer DVDs are still a tad pricey, about £5 per disc, but they'll come down in price. In the mean time, you can burn CDs and single layer DVDs as usual.
LiteOn SOHW-1633S rocks your socks TBH.
I think you'll find, on comparison, the NEC is a smidgen better than the LiteOn.
Hi Mariglenn
Please can I ask where you are getting dual layer disks for £5, last time I looked they where £15 EACH.
Chilly
PS I have the NEC ND-2510
holdtight
Thanks for the link mariglenn thats the cheapest ive seen
have you tried these disks yourself?
if so anygood ?Huh
I buy all my CDs/DVDs from there. No complaints yet! Cheesy
Doubtful, NEC make very poor hardware (I know people who work for them who won't even touch the hardware even with the discounts they get).
I get all my media from http://www.svp.co.uk/ top people there, and if you spend more than £20 and order before the end of Sunday use this promo code for 5% off: SHIPFORLESS
