DTP Software
DTP Software
publisher?
im sure adobe make one, inpage or somthing
DTP Software
Can anybody recommend a decent, powerful DTP application for Windows XP?
At present, I use Scribus within SuSe Linux for my DTP needs (mainly newsletter design and production) However, when I start my new job in September I will be using Windows XP most of the time, so I need something which will run on this.
Ideally, I would be looking for a package with integrated PDF support (export) however I could do this using other methods is needed.
Opensource software in preferable, although I would also consider commercial alternatives.
Cheers Smiley
DTP Software
I've always found serif pageplus 10 very good; unless you get a deal through your school / college it's a little pricey though (the current version is 11 which I havent used).
However older versions are avaiable from http://www.freeserifsoftware.com/ for free...
DTP Software
Openoffice org. is a free office suite
Mine has an export as .pdf button on it, but I also have adobe, so I am not sure if it comes as standard or not.
It has that nice linux feel and is compatible with msoffice 2000/xp. (Save as the relevant office file.)
http://www.openoffice.org/
for the free download
Denzil
DTP Software
Openoffice is good, and can do simple layouts, but it is not as flexible as a dedicated DTP package. Serif Pageplus is quite good, as Daniel says. I use Adobe InDesign at work, which is very good but expensive.
If you are used to Scribus I think it has been ported to Windows, although I don't know what stage its development is at. Must be worth a look.
