DSL-300T and DI-704P
Hi
I have just got my plus-net account activated. Very impressed so far. However, I cannot get my new DSL-300T to connect through my DI-704P router. I used to use NTL and had no problems accessing the net.
The new modem works correctly if attached straight to the machine, but I cannot see the modem if I connect my PC via the router an dcannot surf the net.
Any ideas would be most appreciated.
Chris
1 REPLY
Try changing the routers default IP address to
a different range than the modem. If the modem
defaults to 192.168.0.1 (assumed) and
so does the router, then get into the routers set up
page and change its LAN IP to 192.168.1.1 or 10.0.0.1.
Alec
