DG834 debug mode / editing config files...
I know how to get my dg834 into debug mode but not sure on the easiest way of either editing files in situ or transferring config files off the dg834, editting them offline and returning them to the box... (I want to experiment abit with my iptables settings and know what needs to be done just not the best way of editing the files).
How about this:
Edit your script in the wordpad .. cut it to clipboard
In your telnet window ..
# cat > filename
Paste the clipboard .. and CTL-D when you're done .. Good luck!
DOH!
Should have thought of that one...
Ta,
Just make sure you keep a copy of a decent firmware and the recovery software, just in case it goes pete tong.
Don't worry... I've got atleast three seperate copies of the recovery stuff and current config etc (+1 on my usb memory stick).
Spent too long with dead routers once things have gone wrong to get caught out like that.
I wish knew enough the software running of them to make tweaks to it, I've been looking for a site with tweaked versions but I've not found many.
