DFI flash bios gone wrong, help
I have the DFI LanParty NF4 SLI-D and have just flashed the bios, I now get the message reinstall file root\system32\hal.dll. Anyone know what as happened and what to do next, please. Used the floppy disk method.
If you can't boot into windows try this -
Boot from your Windows XP CD.
Choose the Repair option, "R"
Chose the location of your drive normally this will be 1
Enter bootcfg /rebuild to repair it
Restart the computer.
That should do it.
Thanks Chriss, just realised that the reason I can't boot from CD is I have a wireless keyboard, Doe
Ohhh - do you not have an old ps2 one or a mate who has one?
I forgot that I use a wireless keyboard and when it said press F1, i was stuck so had to hard reset instead. I bought a wired keyboard and have run the recovery consol and I can now boot my system. However, when the system boots up I now get the option to boot up using 2 xp systems! The first one in the list there is no writing for, which is the 1 that works, the second 1 it must have found on another disk, Doe. Thanks for the reply and help Chriss.
By the sounds of that your Boot.ini has added an extra line - you can edit it doing this -
Click Start / Run, type sysdm.cpl OK.
Click the Advanced tab
In Startup and Recovery click settings then click edit
The Boot.ini will open in notepad -
Does it show like this?
[boot loader]
timeout=30
default=multi(0)disk(1)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(1)rdisk(0)partition(1)\WINDOWS="Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Windows XP Professional" /noexecute=optin /fastdetect
If it does you can delete the line that is not relevant to look like this -
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Professional" /noexecute=optin /fastdetect
