Connecting to FTP
Connecting to FTP
SPI would have no effect on connecting out, as it only moniters incoming packets to see if they match ones that went out already. no filtering is done in -> out, only out -> in.
have you tried it from commandline? (start -> run -> cmd -> ftp -> o ftp.plus.net)
are you sure you typed the address correctly/
Connecting to FTP
Since I've installed my router I've been unable to gain access to my PlusNet webspace Sad
The router has a built-in firewall with SPI so I assume it could be something to do with that.
Using Wise-FTP I get the error....
(500 Connection refused (Winsock error #10061))
Using SmartFTP I get...
No connection could be made because the target machine actively refused it.
I'm a bit lost at what to do. My router is just a cheap SafeCom one from eBuyer. Anybody got any ideas?
Mark.
holdtight
Connecting to FTP
Hi Mark
You dont really need a third party ftp program to access your webspace, try opening explorer and type ftp.plus.net into the address bar you should then be prompted for your username and password
if it connects from here you can drag and drop your files where you want
them
if you want to use an ftp program try looking in your router security settings
to see if its blocking ftp for some reason and within the program itself
i find filezilla to be an excellent program you could give it a try
Connecting to FTP
I'm still have no luck. I'm connecting to the right address and I've tried the DOS command but it stiull won't connect Sad
Has anyone got any more ideas?
Connecting to FTP
The url shown above gives me a page not found error. Change it to ftp://ftp.plus.net and it should work ok Smiley
holdtight
Connecting to FTP
Yes it does the same if i try and link to it from here but from inside
explorer it connects just fine with the username and password dialogue
box popping up ?
Do you get "page not found" from within explorer John ?Huh
Connecting to FTP
Funny but yes ftp.plus.net does work fine if I open a new instance of Explorer.
However when it opens the login box then the address bar shows ftp://ftp.plus.net Huh
Connecting to FTP
It just tells me that it can't make a connection to the server. It's starting to become a real problem now.
Do you think it may work if I remove port 21 from my list of stealth ports?
holdtight
Connecting to FTP
Try ftp2.plus.net !
I seem to remember something about ftp2 in a post with someone
having problems but cant find it
John might be able to tell you more about this
Double check that your router or firewall is not blocking outgoing ftp or port 21 for some reason
see if you have port 21 stealthed for incoming as well as outgoing traffic as your problem may lay there
i have seen this happen with some firewalls being over protective also
