Conexant ADSL USB Modem with any Linux
Hello...
I am very tired of Windows, and want to get stuck in with Linux... I have installed the latest copy of Mandrake, but I am unable to use the Conexant ADSL USB modem. Cry
I would appreciate any advice/help from anyone that has managed to use this modem with any version of linux.... I am trying to resit the urge to buy a router Smiley
USB devices is somewhat hit and miss on Linux and support for specific ADSL modems relies on the manufacturer supplying a Linux driver for it or someone else having the requirement and writing one themselves.
Your best bet is to get an external router and connect via a normal ethernet cable to a network card as there are a lot more network cards supported than ADSL modems.
You could ask for help at www.mandrakeusers.org...
... but I've had a quick look at the Linux USB device review, the Mandrake hardware database and www.linuxcompatible.org and it doesn't look promising... Sad
ratbag
I just wanted to sympathise with fernandes. I just started looking into Linux and installed Feroda. I've been trying all over the net to see if I could get my PCI ADSL modem working with it but without luck. I'm now trying to work out what these routers are all about. (more expense!)
Ethernet modem
A router is the best way to go, but if you are looking for a cheaper alternative both D-Link and Netgear do Ethernet modem’s for £60 to £70. (about ½ the cost of a router.)
http://sourceforge.net/projects/accessrunner/
Looks pretty straight forward. Smiley
A quick google found it: http://www.google.com/linux
And if you get stuck.. try: http://www.linuxquestions.org
Ok my pricing was a little "high Street"
Check out;
http://uk.pricerunner.com/networking/broadband-gateways/
I'll just point out that you need to be aware of the difference between a gateway and a router - gateways actually have to have a modem attached, routers are an all-encompassing solution.
Thomas
Hi all
Thanks for the advice... I'll probaly invest my hard earned cash into a nice little router :?
Have a good weekend
Dan
Why spend money..
Has a driver, which will work fine! Could at least try it first!
