Cascading Permissions
jabb0
heya,
I have installed Ubuntu quite successfully.
However when moving from windows, i backed-up all my required data - and successfully copied it to my home dir.
Now there is literally thousands of files, and i do own them all in ermissions, but write access is not enabled on them.
Can anyone show me a command to change the permissions of my files to give me write access to - all of them in the one go?
It either this or change the permission of each file individually - which would just be soul destroying.
1 REPLY
chmod -R 755 <directory name>
This will recurse down <directoryname> changing all files and directories it finds to 755 permissions.
You can also do a recursive change of owner & group with
chown -R owner.group <directoryname>
Also see CGI: UNIX file permissions
