Cant get to dios screen???
Got the new 500 watt psu set it back up again and it powers up but it wont get to bios screen. Any ideas. It
press the delete key a few times as soon as it powers on and shows the disk setup or memory test. Sometimes it's F1 or F2 - it should say on the power on screen what key to press to enter BIOS or setup.
Or just hold a key down when switching on and it should give you the option to go into setup/BIOS.
Try reading the motherboard manual, it will tell you what key to press to enter setup or BIOS.
Why did i put dios. Just tried them and no luck i think the corner shop is in need for this know
does it boot ok?
Its all going back now apart from the monitor and 8 quid speakers bargain they was. I am not buliding my mate one again to much hassle
