Cannot view web sites...
Hi, i have a small problem that i am not experienced enough to fix...i Have windows xp and a binatone 500 adsl modem...i can dial up to my isp and it says that i am connected, however when i try and load a web page i get a ...page cannot be displayed message....i have disabled my internal modem, also i have ping the dns server ip address and its ok....my connections say that i am connected...however i cannot visit the internet...i believe its something trivial...i have tried help and support for internet explorer and that cannot help me.. i have also disabled my firewall...and disabled norton...can anyone help me...it would be much appericiated...
many thanks
The Rookie
If you enter ipconfig /all at a command prompt, what gets shown as the DNS servers?
If no entries are shown, try configuring 212.159.13.49 and 212.159.13.50.
In adition, have you got XP Service Pack 1 or 1a installed?
If not, this sounds like a possible suspect.
There apparently should be two MS hot fixes on the modem disk that deal with the specific problem, however, SP1/1a have addressed the issue further , so should be installed anyway/
i have ping the ip address for the dns servers on command prompt!!! and also i have reinstalled the windows xp service pack 1....everything was workin fine on my pc until recently...the modem works fine on my laptop...hence how im able to communicate...currently on the net.
What happens, though, if instead of ping 212.159.13.49, you try ping pth-cdns-01.plus.net?
Does it still work?
If it does, then DNS is not your problem.
If it doesn't, then you need to look at your DNS configuration.
Does it still work?
yes it doese connects to the dns server....but gets timed out when i ping anywhere else. I might of changed something on internet explorer. A few days ago i uninstalled AOL 7.0 als AOL start up could this be something to do with it.?.......its all been working fine until recently.
[Moderators note (by Thomas): Quote UBBC tag fixed for you.]
So, if you were to ping www.google.co.uk ( or ping 216.239.59.99 it would time out?
What about a tracert www.ggogle.co.uk? What does that show?
And a pathping www.google.co.uk?
ok...ill give that a go..and see what happens.....thanks
