Cannot set 16 Bit Colour
I have an AS4431D iiyama monitor.
the problem is that: I cannot set the 16 bit colour setting to work without a pattern of vertical lines on my screen. Can you advise me of what I might do to remedy this.
My set up is as follows:
I have;
Windows XP pro
A Gigabyte Radeon 9800 Pro 128 Video card
A LLiama AS4431D 1280x1024 LCD Monitor-(using digital connection)
Pentium 4 3.2Gb
1Gb RAM
Peter
check for updated drivers. Check the properties of the video I would suspect the refresh rate may be set to high drop it down to 60 hzs and work your way up
I have binned the rasdeon 9800 and got a geeforce 6800 instead;result; perfect graphics in all resolutions and colour settings.
peter
